51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> COST ESTIMATING WITH REVIT
Mon, Nov 14, 2005 at 9:40:50 PM | COST ESTIMATING WITH REVIT
CHADROBERSON
Has anyone figured a way to do cost estimating with REvit
Thu, Dec 28, 2006 at 11:27:21 AM | COST ESTIMATING WITH REVIT
Jeremya
I've used it for residential purposes with the scehduling.  REVIT will allow you to write equations and those are expressed as columns in the schedules.  I've written schedules for walls, floors, ceilings, etc., that when I schedule the wall I can derive costs from the information already defined or associated with the wall.  The great thing is REVIT will export a schedule to Excel which you can then customize to your hearts content the information you want to derive from the data inported from REVIT.
Thu, Dec 28, 2006 at 11:45:22 AM | COST ESTIMATING WITH REVIT
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Check out US Cost Success Design Exchange - it's a software that uses assembly codes from the Revit model & the US cost database to generate cost estimates from the bim model.
http://www.uscost.com/designexchange.asp
Hiroshi Jacobs
Thu, Dec 28, 2006 at 12:29:42 PM | COST ESTIMATING WITH REVIT
coreed
coreed Avatar
4 Stars: 16 Votes
check out this recently posted thread, it may be of help
http://www.revitcity.com/forums.php?action=viewthread&thread_id=6102
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jul 12, 2010 at 9:39:43 AM | COST ESTIMATING WITH REVIT
gehatg
In our company we use CostOS Estimating it has an embedded visualizer where you can select entities and directly estimate what you see using commercial databases check it out:
http://www.nomitech.eu/cms/en/c/bimestimating.html
Revit & Cost Estimating
Mon, Jul 12, 2010 at 9:42:34 AM
Cost Estimating Software for Revit 2010
Fri, Jul 16, 2010 at 9:54:05 AM
cost estimating programs with Revit
Tue, Oct 11, 2011 at 9:10:17 PM
Exporting Revit to Master Builder Estimating Software
Wed, May 21, 2008 at 8:19:43 AM
Exporting model's information to a spreadsheet like MS Excel for cost estimating
Wed, Nov 4, 2009 at 10:38:54 PM
Page generation time: 2.7282
