87 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> Creation of a new Material Surface Pattern
9 Posts No Rating |
Hi,
I need to either modify or create a new surface pattern for a material. How do I do this?
Thanks,
E
Autodesk Revit Architecture 2011 x64
10 Posts No Rating |
Try this link it helped me out.
http://www.youtube.com/watch?v=iB4BVcS7z6w
![itsmyalterego Avatar](user_avatar/109615.jpg)
There was another post today about surface patterns. I would definitely look into the "hatch22" plugin. probably easy to google. Works with 2011, and it allows you to draw a hatch pattern to the exact scale you want, with lines, and then transform your selection into as a model hatch. Or a drafting hatch if you prefer.
WWhub once said it might not export to cad. That's easy to imagine. But if you don't need to export for whatever reason, it seems to work perfectly within revit itself. I've used it on several projects now, and it REALLY beats the hell out of messing with old ACAD .pat files and thier funky scaling.
Hiding Surface Pattern For Specific Wall Material |
Thu, Feb 21, 2008 at 10:47:29 AM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
View dependent material surface patterns |
Wed, Apr 22, 2015 at 1:57:55 PM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Surface Pattern of Material |
Wed, Aug 31, 2005 at 5:25:37 PM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
