80 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Slab cutting out columns! Any way to stop this?
Wed, Apr 13, 2011 at 8:51:54 AM | Slab cutting out columns! Any way to stop this?
structuresguy
Hi.  I have a case where I have a site slab in my model, that cuts through many exterior columns.  I don't want to show the site slab normally, so when it is turned off, all my columns have a section cut out of them.  I don't want to spend the time to draw openings around each column in the slab, as there are lots of them.
Is there an easy way to tell Revit that the column has preference, not the slab?  if anything, the slab should be cut out at each column.  The fact that it is reversed is typical of the problem when you have people who don't know what how things work in the structural world creating software.
I have attached an image of the problem.
Thanks.
Fri, Apr 15, 2011 at 8:20:08 AM | Slab cutting out columns! Any way to stop this?
jnovella1520
Hello,
You could create a new design option, and place the slab on option 2 Cryingnot the primary option).
Fri, Apr 15, 2011 at 8:31:02 AM | Slab cutting out columns! Any way to stop this?
jnovella1520
Sorry not sure what the little image was thats inserted after the option 2.  Anywase, another method is to create the site slab in a different Revit file and link it into main project model (not ideal, but works too)
Fri, May 6, 2011 at 10:53:31 AM | Slab cutting out columns! Any way to stop this?
structuresguy
thanks for the ideas.  I think I will try using a separate model for all site objects, and just link them in.
Fri, May 6, 2011 at 11:53:28 AM | Slab cutting out columns! Any way to stop this?
Edit your slab, then when it asks if you want to cut out intersecting walls answer no.
Other option is to edit your slab and sketch holes in it where your columns are.  That would be the right thing to do.
Fri, May 6, 2011 at 12:13:20 PM | WWHub
structuresguy
Quoting WWHub from 2011-05-06 11:53:27
Well, it never asks me to not cut out intersecting walls.  And actually, the slab is not cutting out walls, only columns.  Why the programmers would give priority to a slab over a column is beyond me.
Fri, May 6, 2011 at 1:04:58 PM | Slab cutting out columns! Any way to stop this?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Perhaps the uncut geometry tool?
Are you sure it's a site slab, and not a structural foundation slab?  I believe that might act a little differently with structural columns,which brings me to, are those structural or architectural columns?
Wed, May 25, 2011 at 5:37:13 AM | Slab cutting out columns! Any way to stop this?
gprakash
structuresguy,
How about 'UNJOIN GEOMETRY' and just one click on the slab? Just checked with this and was successful in showing all structural columns without cut out while the intersecting slab is hidden.
Wed, Jun 11, 2014 at 4:58:18 PM | Slab cutting out columns! Any way to stop this?
SchmiedCHI
gprakash gave the answer that helped us out in a 'cut column' situation (using UNJOIN)  Thanks!
Concrete Slab Edge Angles
Wed, Dec 7, 2011 at 12:35:25 PM
13
Cutting a Column for Different Phases?
Tue, Jul 2, 2013 at 9:05:31 PM
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:14 AM
hidden columns
Fri, Mar 26, 2010 at 10:53:37 AM
Trouble Cutting Columns
Mon, Feb 24, 2014 at 8:34:08 AM
Page generation time: 1.6080
