Forums >> Revit Building >> Technical Support >> Family Will Not Load
86 Posts No Rating |
Hi there,
I downloaded a column from RevitCity, and then adapted its aesthetics to how I wanted it, and now it will not load into my project. I've tried loading it into new projects too but no luck. It comes up with a 'type' error.
I spent hrs making this thing (and now realise I should have tested it loading before finishing making it) - if anyone can assist with helping this load, I would very muhc appreciate it!
Thank you!
I took that family and tried to beat some sense into it, but I've been beaten. It's extremly screwed up, somehow, I can tell you that. I think a large part of the problem is that there are several "types" that it is trying to make with a bunch of parameters still in the family, and I cannot remove the column types, or the parameters they use. And I cannot find any geometry that relies on the parameters.
They're like ghosts of the old family. I know there are gurus on here who could figure it out, but it's going to be a time commitment for them, regardless.
I would start with a fresh family template. You never know what you're getting with a download from here.
Edited on: Tue, Apr 12, 2011 at 6:25:04 PM
curse- well thank you very much for trying and fingers crossed a guru might be able to shed some light on the problem- thanks heaps
Cannot load family |
Mon, Apr 18, 2011 at 5:22:02 PM
Reivt will not load door family |
Tue, Oct 11, 2011 at 7:23:13 AM
the load in family not working |
Fri, Aug 19, 2016 at 1:01:12 AM
Load Family button does not pull open the file browser |
Wed, May 4, 2011 at 1:55:38 PM
Revit Cannot Load Family |
Mon, Aug 1, 2011 at 7:20:35 AM
Members: | 2115582 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
