42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 4:47:18 AM | New to revit and have a question... Re: walkthrough on 2011
Shenene
Hi, I'm quite new to Revit.
I've made up a walk through, but would like to try a Rendered walkthrough, I waited 2 days! and the walkthrough is completely dark except for the exterior parts of the building before you walk in.
The only settings I know to use for a normal Render, not a walkthrough is to choose 'sun only', 'cloudy' and 'sun from top right'.  I thought I'd better ask if this would work for the interior walkthrough before I wait another 2 days to find out :-)
Cheers,  Shenene
Tue, Apr 12, 2011 at 9:14:10 AM | New to revit and have a question... Re: walkthrough on 2011
JWebber
You might be having problems with your hardware and or video card. Does your system meet or exceed the reqiurments for revit 2011 specs?
Tue, Apr 12, 2011 at 12:30:44 PM | New to revit and have a question... Re: walkthrough on 2011
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
well, a walthrough renders each frame.  So it takes hellishly long.  default walkthrough is 300 frames, to get some smoothness, I usually use something like 3000 frames.
It would be difficult to make a walkthrough that goes from outside, to inside. In other threads, people have asked this question, and one solution that people have come up with is to do two seperate walkthroughs, one ending at the door, and one starting at the door.  And then combine them into one video after the fact.  actually, the same walkthrough, just starting at the frame you stopped at with different settings.
The reason being, for outdoor renderings, you have the sun as your light source, and it's ridiculously bright.  And inside, you only have a few windows, and light bulbs, which are an order of magnitude more dim.   So any render settings that you've set to look good outside, with sun, will make your interior renders virtually black.
You'll need to add some daylight portals, and/or light fixures to get any sort of render out of your interior though.  So that takes some work--and as soon as you start adding multiple light sources, the processing required to render goes up outrageously.
I hope I'm not sounding too discouraging, but what some firms do, if they really need some beautiful rendered movie, is to send the file to a rendering farm.  basically a super computer that can do in minutes or hours what your desktop could do in days or weeks.
I've also generally been satisfied with shaded with edges walkthroughs.  it's possible to clean these views up enough to be presentable. turning on shadows, etc.
Tue, Apr 12, 2011 at 6:01:12 PM | New to revit and have a question... Re: walkthrough on 2011
Shenene
Hi,  Thank you so much for the replies.  My computer specs should be all good, as it's a fairly new computer.
I will definately try the walkthrough as you suggested and see what happens :-)
Thanks,
Shenene
2011 Revit Architecture Export Walkthrough CODEC
Tue, May 18, 2010 at 9:43:10 AM
Walkthrough Not Registering [ 1 2 ]
Tue, Jul 26, 2011 at 4:51:50 PM
15
walkthrough questions
Mon, Mar 25, 2013 at 2:44:09 PM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
Walkthrough Rendering
Fri, Apr 30, 2010 at 4:26:13 PM
14
Page generation time: 2.5952
