Forums >> Revit Building >> Technical Support >> Radial dimensions won't display but linear will?
21 Posts No Rating |
Hi there Revit Fans!
I'm working in RAC 2011 and am dimensioning a reflected ceiling plan with some curved soffits. All the linear and aligned dimensions display just fine, and yesterday morning I was able to create radial dimensions that displayed. Today, when I attempt to place a radial dimension I get the error message about it not being able to display in the view and to check my settings. My VG settings are all fine, and the dimensions aren't hidden in view because I can still see them all.
Any ideas about what might be going on here? It's Saturday and I'm losing my patience on this one. Might be time to go home.
As always, any tips, pointers, hints and help are greatly appreciated.
Thanks!
mb
Revit 2020. I am having the same problem. What settings to look for?
Update: the center of the radius was outside the crop view. Is there a way to show a short arrow with the unit length without having to extend to center of radius?
Edited on: Thu, Jan 23, 2020 at 10:39:48 AM
Untick ‘center marks’ in dimension type properties and pull blue grip dot towards the object.
Thank you!
Some furniture won't display |
Wed, Jul 12, 2006 at 5:39:40 PM
Room Separation Lines won't display [ 1 2 ] |
Mon, Feb 19, 2018 at 2:00:11 PM
15
Change start and end heights of elements in radial array |
Tue, Sep 20, 2016 at 7:06:49 AM
Radial array in Families |
Tue, May 28, 2013 at 3:04:01 AM
Linear lights aren't linear at all? |
Fri, Feb 4, 2011 at 1:54:01 PM
Members: | 2115615 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
