39 Users Online (38 Members):
Forums >> Community >> Newbies >> Building Pads...how to see existing pads when outlining a new one?
![ArchiN00B Avatar](user_avatar/160085.jpg)
![4.5 Stars: 4 Votes](/images/stars_4.5.gif) |
Hi,
I am trying to create building pads at a couple different elevations, but run into the problem of inevitably overlapping one by a few inches...
I know they can border, but not overlap, so is there any way to have other building pads highlighted while you are creating a nearby one so that you can border right up against them?
I know one answer is: just use pick lines/walls and keep track of which lines are where. But with a big project, it is getting hard to keep track of all of this.
Much thanks for the help!
![nastyclown Avatar](user_avatar/114560.jpg)
![4.5 Stars: 9 Votes](/images/stars_4.5.gif) |
i dont know if there an easier way... but what i do in this cases is copy/paste on view same lines. I mean copy from one pad, creating new one ( next to the one i copy) and then pasting in view (plan view)
I have found most of the cases works, but it haves problemswith arcs... Hope it helps
![mcantwell Avatar](user_avatar/22237.jpg)
I cretae a 3d and plan "pads only" view with nothing but the pads visible.
It halps a bit to see whats happening.
Ok, thanks. I'll give those a shot!
Adjacent building pads: toposurface popping up between |
Wed, Nov 20, 2013 at 10:22:59 AM
Topography and pads trick |
Mon, Jan 14, 2013 at 2:53:18 PM
Sloped inscribed building pads have topo 'walls' |
Wed, May 6, 2015 at 7:25:40 AM
Pads and phases |
Wed, Mar 28, 2018 at 6:44:33 AM
Pads/Phases AGAIN! |
Thu, Aug 9, 2012 at 3:14:53 PM
Members: | 2022237 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
