45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Help with a custom tag
Fri, Apr 8, 2011 at 10:23:15 AM | Help with a custom tag
DeifyMe
4 Stars: 2 Votes
My company makes modular tilt up wall panels. Typicall they are 4' wide unless noted otherwise. I've trying to make a wall tag that shows the Panel Mark and the width. The key thing is that if the panel is 4', i don't want the width to show up. I'm trying to set a visibility parameter (YES/NO if(Width<48") but can't seem to get the formula to recognize the Catergory Parameter for Width. Any advice? Thanks
Fri, Apr 8, 2011 at 10:46:02 AM | Help with a custom tag
TKennedy
4 Stars: 7 Votes
Yes/No parameters are a little funny, they seem to assume that the formula is an 'if' statement. Try just entering *Width > 48"* (no asterisks). If the formula is true the parameter will be checked, if false, unchecked.
Fri, Apr 8, 2011 at 10:51:18 AM | Help with a custom tag
DeifyMe
4 Stars: 2 Votes
You're right, I was trying to insert the statement incorrectly. I corrected this but its still staying "not a valid family parameter". I'm trying to link the statement to a Category Parameter and not a family parameter.
adding arrow head to custom tags
Sat, Aug 3, 2013 at 9:49:16 PM
Arrow head placement in custom Tag Families
Tue, Nov 4, 2008 at 1:39:47 PM
spot elevation & custom pipe tag
Mon, Mar 24, 2014 at 10:29:53 AM
custom section tag woes
Tue, Jul 24, 2012 at 4:47:03 PM
Custom Annotation Tag and its Leader
Thu, Dec 31, 2009 at 3:02:55 PM
Page generation time: 0.4553
