Forums >> Community >> Newbies >> Exporting from Revit
13 Posts No Rating |
I am trying to export some models i have done in revit, some families to be exact. I have asigned some materials and colours to my model in revit and I want to export them into Auto Cad. For some reason when I export they loos all colour and the whole model comes out black (using true colour export) and when I export my model using Index colours, the whole model comes out pink.... Can anyone please help....
export as fbx file, uncheck the box "import as block" ..... before importing assign real units, like meters, feets, etc.
why you want rendering info into autocad?
its not that i want the rendered info in auto cad, I just want it to keep the colours that was assigned to it, the materials doent bother me, its just the colours. becuase the whole model comes out black...
So I export the revit file as an FBX file fomat, and than import that into auto cad?
The colors of the different elements are defined in the txt file ( that you can edit, or choose from one thats already set, like the aia standard ) when you export a dwg under the "dwg properties" tab, there you can edit the colors of the elements (red is 1, yellow is 2, and so on, check the number/color in autocad)... as are in revit categories. Leave it as index color.
A different case is the room colors... you can export it with true color, but all the layers have the black/white color assigned. I suggest stick to index color, and manually re-color the hatchs. It will be less pain than changing every layer.. than some rooms.
Trouble w/ exporting to AutoCad |
Thu, Jan 20, 2011 at 11:18:07 AM
Exporting revit to use with Lumion |
Tue, Jan 8, 2013 at 3:39:59 AM
Exporting from Revit and into 3D Studio Max |
Wed, Oct 31, 2007 at 1:25:11 AM
Exporting REVIT 8 Model to Photoshop7 |
Wed, May 18, 2005 at 11:50:04 PM
Dimension problem when exporting Revit to DWG |
Tue, Apr 12, 2011 at 11:15:43 AM
Members: | 2115639 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
