106 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> importing sketch up files
Wed, Apr 6, 2011 at 6:03:24 PM | importing sketch up files
Willemvans
I have found a couple of 3D models on google warehouse and as I believe they are in sketch up. When i download these files i cant seem to bring it into revit, Can anyone please help?
Wed, Apr 6, 2011 at 6:39:02 PM | importing sketch up files
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
sketchup models have a .skp suffix.   When you go to import cad, you can choose the file type you're trying to import, and .skp is at the bottom of the file type drop-down.
I don't have much experience working with sketchup models in revit, from my limited experience they're quite rigid.  To a small degree, you can explode sketchup models into smaller geometries, but that's about it.
You probably want to import your models into new families first, save those families, and load those into your project.
Wed, Apr 6, 2011 at 6:56:22 PM | importing sketch up files
Willemvans
does the version of sketchup make an impact?
Because I tried to import that into a new family template, but it gives me the message of "can not import"
So are there some settings I need to look at before importing? Or is it just a hit and miss with the sketch up models on which will work and which wont?
Wed, Apr 6, 2011 at 6:59:32 PM | importing sketch up files
itsmyalterego
4 Stars: 16 Votes
Hmm.  I'm not sure.  I do know that importing into a "mass" family will have more success.  But there are a lot of links to similar questions down at the bottom of this page.  I know this question has been asked many times before.  browse around a bit.
Thu, Apr 7, 2011 at 4:12:05 AM | itsmyalterego
4 Stars: 202 Votes
Quoting itsmyalterego from 2011-04-06 18:59:31
Ditto
importing sketch up models
Thu, Aug 16, 2007 at 3:08:24 PM
Sketch up to revit
Tue, Mar 26, 2013 at 7:31:18 AM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES
Sun, Sep 24, 2006 at 10:37:22 PM
Importing DWG files
Wed, Jan 25, 2012 at 10:45:58 AM
Sketch up
Thu, Mar 15, 2007 at 6:46:51 PM
Page generation time: 0.4908
