Forums >> Community >> Newbies >> Dang Topo Subregion!
Hi everyone,
So I created a subregion on my topography a while ago, and now I want to erase it (meaning merge it back with the original one, not delete it so that there is a gaping hole!).
I have RAC 2010. Is this possible?
it sounds like you used "split surface" instead of "subregion."
You have a tool called "Merge Surfaces" which can combine the two surfaces into one again.
Unfortunately, it is a topo subregion, and merge isn't an option. When I hover over it, it is a subregion, and i can change the material (as long as it is in the site category), but I can't get it to rejoin the main topo...
any ideas?
21 Posts No Rating |
Sounds to me like you've made a subregion, then when you wanted to delete it, you've edited the boundary and deleted the boundary lines and finished subregion. This will leave you with a 2 topograpghies that won't merge.
Try copying your topograpthy, then paste aligned, then delete the old one.
Hi, thanks for the response. Pasting aligned worked!
1 Posts No Rating |
Its actually much easier that you would expect. I looked and looked for the longest time and didn't find any tool, so i just clicked on it. when its highlited, just press the delete key on your keyboard, and it will revert back to the original region-less topo. do this for any sub-region you wish to rid yourself of. If you are using phasing in your model file, it is much better to use the split surface tool and create a new surface for the new phase.
-Dae-
Subregion changes topo's elevation? |
Mon, Nov 24, 2014 at 4:12:41 PM
Topo & Subregion issue |
Mon, Sep 1, 2014 at 6:27:01 PM
Topo Subregions |
Wed, Jun 17, 2009 at 3:14:28 PM
How to remove Topo lines in subregions |
Sat, Mar 22, 2014 at 8:27:17 AM
Topo material color not showing? |
Thu, Nov 26, 2020 at 11:24:42 AM
Members: | 2102383 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
