51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> i connot copy the wall on my COPY-MONITOR tools
Sun, Apr 3, 2011 at 9:01:18 AM | i connot copy the wall on my COPY-MONITOR tools
albertiglesia
albertiglesia Avatar
i do not understand why i cannot copy the wall from copy-monitor tools? on the process, the wall can be selected but when it is finish the wall is not appearing and is not coppied, what is the problem? what are the cause for these problem?
please help me
"Pleasure in the job puts perfection in the work"
 - Aristotle
Sun, Apr 3, 2011 at 9:02:42 AM | i connot copy the wall on my COPY-MONITOR tools
albertiglesia
i am using revit structure 2011
 - Aristotle
Mon, Apr 11, 2011 at 11:51:17 AM | i connot copy the wall on my COPY-MONITOR tools
albertiglesia
this is solve now and i know now the reason why after i tried to solve it because of tramendous curiosity. the reason for this is COPY-MONITOR in revit structure will only work if the element that you want to copy and monitor is classified as structural (if you are using revit structure), this is the same with the column, if the modeller does not classified the column as structural then copy in copy monitor will not work
 - Aristotle
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:28 PM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:24 AM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:53 PM
Copy - Monitor - Openings
Wed, Jul 23, 2008 at 12:23:28 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:29 PM
Page generation time: 2.8154
