Forums >> Workflow & Implementation >> API & Third Party Apps >> Ivy Generator
5 Posts No Rating |
Does anyone know how to get ivy into revit to grow on walls or objects? I found a free program online but it only takes object files and I don't know if you can bring revit riles into it.Any help would be apreciated
http://graphics.uni-konstanz.de/~luft/ivy_generator/
Look at the bottom of this page, you will see similar threads about this issue
5 Posts No Rating |
I looked through the other threads before I posted and it apeared that no one really knew of a good way to get ivy or use that ivy generator.
Look this image from "Erland73" http://www.revitcity.com/gallery.php?action=view&gallery_id=9938
A good texture can do what you want
another solution is with the ivy_generator, there is various versions ... but as typhoon writes, its better to make it with a texture, or add it later with photoshop
Does anyone have any suggestions for creating IVY? |
Wed, Oct 8, 2008 at 8:07:30 AM
Wall Ivy |
Sun, Jan 15, 2012 at 7:48:36 AM
Plant request - I am looking for some vines or ivy perhaps. |
Thu, Dec 3, 2009 at 10:08:27 AM
ivy plant |
Tue, Jul 28, 2009 at 6:29:18 AM
Attempted solution to the problem of IVY/Creepers |
Sun, Apr 27, 2014 at 11:11:24 AM
Members: | 2115521 | Objects: | 23192 | Forum Posts: | 152305 | Job Listings: | 3 |
