Forums >> Revit Building >> Technical Support >> Help loading vehicles into project
5 Posts No Rating |
I'm trying to load a vehicle into my project. I open the download file and click 'load into project.' then i have an error come up that says 'can't create this kind of element in this view in the current mode.'
what view do i need to be in? what mode are they talking about?
thanks for the help!
First question is what view were you in?
Obviously if you are in a non-model view like a legend or a schedule then you can't place a model element. Beyond that, hosted elements require you to be in a view that works with the host. Floor hosetd, you should be in a plan view. Ceiling hosted ... RCP. Etc. For most site related items, you want to be in a plan view.
5 Posts No Rating |
i'm working in the first floor plan view. the wierd thing is that it doesn't even give me a chance to place the element. as soon as the vehicle loads into the project it gives me the error.
Sorry but you really don't give us much information. I don't know anything about a vehicle (which one) downloaded (from where) or how it may be hosted.
But you can switch views and try again. BTW .... Just because you can see a plan doesn't mean you are in it.
5 Posts No Rating |
Can you please post here that "vehicle" so we can take a look?
I wonder if this vehicle is done as a conceptual mass, maybe you'll have to insert it while in Mass in-place
3 Posts No Rating |
i have a similar prblem
I had loaded my vehicles but in my fist floor i cant see them
I only can whenÑ
1) active "reveel hidden elements" but they dont have a color of hidden
2) In 3D with camera and secciion they are visible
I loaded another vehicles but the problem is not solve
please im waitin for ur opinion
the error is normal when you load a family in because revit will go to the first view opened which may be a drafting view or some other non-model view. If the vehicle family is set to "Entourage" category and you see the vechile in Reveal Hidden elements then you need to turn on that category in the Visibility/Graphics Dialog box.
3 Posts No Rating |
I used "APly default view template" and let me see the vehicles and other objets than before can see them
are you using the insert menu to load?. ie. if you try to load a door when youre in the window menu you get an error msg that it cant load.
3 Posts No Rating |
thanks!!
