95 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DIMENSIONS OVERRIDES
Mon, Nov 14, 2005 at 4:11:47 AM | DIMENSIONS OVERRIDES
jyothi
hai all, i have got a problem with dimensions, i need t override the dimension which is actual with the diff dimension.For Ex: if distance between one end to other is 25' if break lines are used in between to reduce the size on the sheet, how do we get that 25' lenght whoch is acutally not when measured. like in autocad where in we can do dimension override. is there any method to do so . it will be of great use if any one can help. thank you,
Mon, Nov 14, 2005 at 11:01:59 AM | RE: DIMENSIONS OVERRIDES
Scott Davis
3.5 Stars: 3 Votes
if you are breaking the plan/section using the Revit break symbols, the dimensions will read correctly across the break. Look on the border of the crop region of a view, there are little blue break symbols. Clicking these will put a space in your view, which can then be adjusted using the blue arrows. Dimensions across these areas will read the real dimension.
Thu, Dec 6, 2007 at 1:27:36 PM | DIMENSIONS OVERRIDES
K8vitali
I THOUGHT THAT ONLY WORKED FOR PARAMETRIC DESIGN, AND NOT FOR 2-D DRAFTING IN REVIT? I HOPE I AM WRONG... INTERESTED TO SEE AN ANSWER
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
Where has my Editing Multiple Dimensions capability gone!?
Thu, Jul 24, 2008 at 1:06:16 PM
Phase Graphic Overrides
Wed, Jul 10, 2019 at 4:01:45 PM
Visibility Graphics/Overrides COMPLETELY grayed out. Revit Structure 2013.
Tue, Mar 27, 2018 at 3:22:42 PM
conflicting graphic overrides...
Fri, Oct 12, 2012 at 10:44:04 AM
Page generation time: 0.3359
