68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Problems with door rendering
Thu, Mar 31, 2011 at 11:39:15 PM | Problems with door rendering
dauten
Hi,
Every door I've tried to render ends up looking like a shadowy block, no detail.  I've tried a number of different ones beyond the "official" Revit door families - same issue.   I also tried going into the materials manager and making sure the material selected for the door panel was wood.  when I look at the door in 3d mode, there's also no panel detail, just a simple panel that looks like a flush door.   I imagine it's some obvious thing I'm doing wrong, but I don't know what that would be.  Help would be appreciated.
Thanks,
Deb
Fri, Apr 1, 2011 at 8:08:24 AM | Problems with door rendering
Materials like wood patterns may not really show in simple 3D mode depending on the material and if a pattern file is set to show.  Look again at the materials.  Also note that the project rules.  Settings in the family are over-ridden by settings in the project for same name materials.
Problems with Best quality nighttime rendering.
Tue, Dec 4, 2012 at 8:32:14 PM
Rendering Problems
Wed, Jun 18, 2008 at 6:48:30 AM
12
Rendering problems
Tue, Sep 12, 2017 at 9:55:22 AM
help with rendering!
Wed, Aug 10, 2016 at 10:47:18 PM
Can a 63mb Revit File Size cause problems during rendering?
Mon, Nov 2, 2015 at 6:29:46 AM
Page generation time: 1.4137
