151 Users Online (150 Members):
Forums >> Revit Building >> Technical Support >> dimensions
52 Posts No Rating |
hai all,
i have got a problem with dimensions, i need t override the dimension which is actual with the diff dimension.For Ex: if distance between one end to other is 25' if break lines are used in between to reduce the size on the sheet, how do we get that 25' lenght whoch is acutally not when measured. like in autocad where in we can do dimension override. is there any method to do so . it will be of great use if any one can help.
thank you,
there is no dimension override in Revit, and I hope we never will!
try to make a moke one, using lines...
EQ Display in dimensions Revit 2009 |
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details) |
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions |
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions |
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared |
Wed, Apr 25, 2012 at 10:37:51 AM
Members: | 2030717 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
