140 Users Online (138 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> View range problem
Thu, Mar 31, 2011 at 4:58:08 AM | View range problem
tossaxe
Hello,For some reason I can't get revit to NOT display a floor below the associated level.
The view range bottom cut and view depth are both set above the floor (not intersecting the element)Tried different clipping options and associating the floor with a different level, Nothing that I can think of helps...
Any ideas? pelase help =]
Thu, Mar 31, 2011 at 8:11:08 AM | View range problem
gebber
gebber Avatar
5 Stars: 4 Votes
try setting it below the floor (bottom & level)
Thu, Mar 31, 2011 at 11:44:49 AM | View range problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I wondering if you have an underlay of the floor below?
Fri, Apr 1, 2011 at 12:17:59 AM | View range problem
tossaxe
Thank You but neither work, it's not an uderlay.. starting to think that it's a system bug =/
Fri, Apr 1, 2011 at 12:28:08 AM | View range problem
tossaxe
Here's a print screen of the problem. I've outlined the troublesome floor red.
Fri, Apr 1, 2011 at 2:14:03 AM | View range problem
gebber
gebber Avatar
5 Stars: 4 Votes
am I correct, you do see this floor in wireframe (as shown in the 2nd image)?
Is there a site above the floor (as shown in the 1st image)?
If so the site might cover up the floor in the shaded view, check your VG.
Fri, Apr 1, 2011 at 12:47:39 PM | View range problem
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
What I see on your posted clips is view depth -120 for level 1 if you don't want to see that exterior slab set the view plane depth above that. If your interest is showing the footing lines and not the small slab just select it and turn it off for clarity, looks like you may have some conflicts there in any case per your section.
View range problem
Wed, Nov 5, 2014 at 10:18:37 AM
Associated levels in the view range.
Tue, Oct 14, 2008 at 2:07:16 PM
View range of structural framing
Thu, Feb 25, 2016 at 6:07:37 PM
view range issues
Tue, Nov 18, 2008 at 5:06:43 PM
view range
Fri, Sep 7, 2007 at 2:28:04 AM
Page generation time: 1.9288
