136 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Material color not the same in different views
Mon, Mar 28, 2011 at 3:58:46 PM | Material color not the same in different views
RainaMc
RainaMc Avatar
Working Revit 2010.  See attached.  For some reason the material color will not display the same in the site plan that it is in the floor plan.  Any suggestions?
Thank you,
Raina Mc
Mon, Mar 28, 2011 at 9:00:30 PM | Material color not the same in different views
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Check the sun parameters, the light amount (direct of the sun, or indirect) can change the color appareance
Tue, Mar 29, 2011 at 9:20:26 AM | Material color not the same in different views
RainaMc
RainaMc Avatar
I went in to the Graphic Display options and changed to match the floor plan view.  It did not change anything.  Thank you.  Any other ideas?
Thanks,
Tue, Mar 29, 2011 at 1:56:31 PM | Material color not the same in different views
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Thats odd... it always works for me. Join the chat room, there is a lot of people that can help you.
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
change shade color in views
Tue, May 15, 2007 at 11:40:20 AM
why shading material color gets overridden by surface color
Wed, Apr 25, 2018 at 9:53:40 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
Material color matching
Wed, Apr 9, 2014 at 9:22:08 AM
Page generation time: 0.6764
