47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to cut the building and not the site?
Thu, Mar 24, 2011 at 2:29:00 PM | How to cut the building and not the site?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I'm trying to show the overall topography of my site plan in relation to the ground floor. The problem is, based on the grade, is that the site is being cut at the level of the plan as well (as I would expect). But is there a way to not cut through the site while still cutting through the ground floor plan? Thanks!
Sun, Mar 27, 2011 at 11:53:07 AM | How to cut the building and not the site?
3.5 Stars: 396 Votes
I take it that your site extends above ground floor.
You clould use an upper level plan then add a plan region around your building and cut that at your gound level.  It would not be your ground level plan as far a any 2D annotations are concerned.
Thu, Apr 28, 2011 at 5:07:32 PM | How to cut the building and not the site?
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I haven't got back to this in a while, but thanks for the reply. The plan region works okay. It's not great. It's too bad it cant make curves since I have a radial building.
Thu, Apr 28, 2011 at 5:45:35 PM | How to cut the building and not the site?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
alternatively, you could put a little/simple plan region out in the topo, instead of a big plan region that covers your building.  A plan region only needs to touch a little bit of an object for all of that object to show, (sometimes a frustration, but helpful in your case) and hopefully your topo is one region.
So set your topo plan region to have extreme view ranges, and that should satisfy things.
Linking Building to site
Mon, Jan 5, 2009 at 1:41:36 PM
Imported Site into Building Model issue
Fri, Jun 27, 2008 at 11:11:54 AM
Building Orientation on a site
Thu, Feb 15, 2007 at 10:07:42 AM
Site Plan & Moving Building Model
Fri, Mar 9, 2007 at 10:22:55 AM
multi building site with phases
Thu, Oct 25, 2012 at 10:35:27 AM
Page generation time: 0.6771
