24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
Mon, Mar 21, 2011 at 3:48:23 AM | Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
mickc55
3 Stars: 2 Votes
Hi Guys!
Exporting as I said, the 2d-dwg files created are coming out as blocks from the linked files. Has anyone had experience with this problem and how to resovle it?
Best regards,
Michael
Be brilliant,
Michael
Mon, Mar 21, 2011 at 7:08:12 AM | Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
Why do you think this is a problem?  This is the way Revit does this.
Mon, Mar 21, 2011 at 7:35:07 AM | Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
mickc55
3 Stars: 2 Votes
Yes I understand but our consultants are using these drawings and they complain that they have to explode the drawings. It would be great if there was an option to not make the dwgs blocks. We have over 60 dwgs that will be this way.
Any tips?
M;
Be brilliant,
Michael
Mon, Mar 21, 2011 at 12:04:29 PM | Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
TKennedy
4 Stars: 7 Votes
I would try to find out why they need to explode the blocks.
Mon, Mar 21, 2011 at 3:03:59 PM | Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
thetabest
thetabest Avatar
3 Stars: 2 Votes
When you export to dwg, you have 2 options, make sure the xref check box is clicked:
 select export tool -> opens export cad formats dialog box, where you can choose the views/sheets you want to export, then click next, if you have the Xref views on sheets check box checked, it should make a dwg for each linked file.  NOW, if it is a CAD drawing linked into revit, then I believe you might be SOL.  But checking that box makes an individual drawing for each linked file.
 Hope it helps
Trent Best
Best Systems
the.tabest@gmail.com
Exporting Linked Revit Files coming in as Blocks
Fri, Sep 2, 2011 at 10:16:39 AM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:37:00 PM
Managing big linked files and exporting to 3ds max
Tue, May 11, 2010 at 8:06:16 PM
Exporting issues... exported dwg files missing information
Thu, Jan 24, 2008 at 11:43:22 AM
Exporting to DWG
Fri, Oct 6, 2006 at 9:08:50 AM
Page generation time: 3.3193
