118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit crushes Materials
Wed, Mar 16, 2011 at 9:07:25 PM | Revit crushes Materials
toxicarea
Ok. I select a component. Then go to properties. Then i go to edit.Then click on material.  Then i go to render appearance. Then select the matarial Grass for example. And then my Revit crushes. Every time. I can not apply any material any more.
Prevously i had a different problem. When i rendered no components were actually visible. I was only seeing empty space on my render. reinstallicng the product twice removed that problem. But now I have this problem. Help!
Thu, Mar 17, 2011 at 7:11:24 AM | Revit crushes Materials
Nobody can help you without you providing more information.
  • Which version of Revit?  Has it had all the updates?
  • What are your machine specifications? Memory?
  • Is the 3 gig switch set?
  • How big is the file you are working on?
Thu, Mar 17, 2011 at 7:30:58 AM | Revit crushes Materials
toxicarea
Ok then. I have:
  • Revit 2011 64x
  • All lates uptades are installed
  • The size of my project file is 12,5mb (the crash happens to all my projects)
  • Machine: Laptop Dell Vostro, CPU i5 M560 2,67ghz, 6GB ram, Video: Gforce M330
program crushes when dragigng
Thu, Dec 6, 2007 at 6:34:21 PM
revit crushes during render
Sat, Nov 13, 2010 at 5:47:47 PM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:49 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:30 AM
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:56 AM
13
Page generation time: 1.9239
