80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Unwanted lines showing through solids
Tue, Mar 15, 2011 at 8:33:14 AM | Unwanted lines showing through solids
xkcurtainwall
I've searched through the boards but couldn't find anything to match my problem. I've modeled some curtain wall and lines behind the gaskets show through (see attached). The lines are (1) part of the gasket and (2) the mullion and pressure plate beyond. I've tried making the gasket thicker and it does hide the lines, but, it's not an accurate representation of the gasket. Is there another solution?
Tue, Mar 15, 2011 at 10:13:18 AM | Unwanted lines showing through solids
We do not model any of this because it severly overloads the model.  In any model perpective view, you will be hard pressed to notice anything missing.  Our model mullions are simple rectangles and the model glass is one piece full thickness.  Then in detail sections, we use detail components that are like what you have modeled.
We also never embed a detail component in the system.  We find it far easier to add these where we need them.
Tue, Mar 15, 2011 at 10:21:30 AM | Unwanted lines showing through solids
xkcurtainwall
Thanks for the info WWHub, unfortunately the customer wants all the parts and pieces modeled. Any thoughts?
Tue, Mar 15, 2011 at 10:38:08 AM | Unwanted lines showing through solids
If you are saying that these lines show in 3D views and are the junction of the glass/gasket .... Well .... isn't that what you have in the real worls that you have chosen to model?  The glass is transparent and you can see these lines?
Tue, Mar 15, 2011 at 11:09:27 AM | Unwanted lines showing through solids
xkcurtainwall
No, the lines (arrowed) are from the mullion and pressure plate beyond, behind the rubber gasket.
Tue, Mar 15, 2011 at 12:50:59 PM | Unwanted lines showing through solids
cdfrantzis
Do you have the view displaying as a hidden line model or wireframe?
Tue, Mar 15, 2011 at 1:02:20 PM | Unwanted lines showing through solids
Do these lines show in a section like you have shown or a different view?  If so, are these lines in the family or extrusions?
Tue, Mar 15, 2011 at 1:11:40 PM | Unwanted lines showing through solids
xkcurtainwall
the view is hidden line view and the lines show up in 3D, section cuts, etc. they are in every view
Tue, Mar 15, 2011 at 1:14:41 PM | Unwanted lines showing through solids
I ask again?  Do you have linework in your family?  Did you use a nested DWG to create your mullions?
Tue, Mar 15, 2011 at 1:23:41 PM | Unwanted lines showing through solids
xkcurtainwall
I'm sorry WWHub, I neglected to answer that. The lines that are showing through are from separate families. The mullion, pressure plate, and gaskets are all separate families
Tue, Mar 15, 2011 at 2:23:21 PM | Unwanted lines showing through solids
#11
I believe your problem is caused by how you created your CW families but without seeing those, I can't help you furthur.
Tue, Mar 15, 2011 at 2:35:13 PM | Unwanted lines showing through solids
#12
xkcurtainwall
I created the curtain wall parts as a generic model by pulling in ACAD drawings and picking the lines to create extrusions with parametric values that allow me to control lengths, etc. in the project. One family for each different kind of part (e.g. one gasket family used at multiple locations). I then created a framework of reference planes in the project and "built" the curtain wall from the various families.
Wed, Mar 16, 2011 at 3:38:56 PM | Unwanted lines showing through solids
#13
xkcurtainwall
For anybody wondering, I ended up just modeling the gaskets "fatter" than they should be and that covered the lines behind.
Wed, Mar 16, 2011 at 4:10:46 PM | Unwanted lines showing through solids
#14
pchan
pchan Avatar
5 Stars: 5 Votes
Is those components were created using "generic model" other than a profile family with a nested detail component. Then you should be able to control the detail level (coarse, medium, fine) from the visibility inside the family. select each geometry inside the family editor and under modify --> visiblity setting you can choose which level of detail to display.
BTW, I am not too sure  why you want to create this "curtain wall" by generic family Not curtain wall system family, but hope the above suggestion will help what you want.
Unwanted printing lines
Mon, Nov 5, 2012 at 12:10:46 PM
Dashed lines in families are showing as solid lines in project
Thu, May 10, 2012 at 8:38:48 AM
In shaded View walls/roofs are showing material and lines behind them
Tue, May 28, 2013 at 9:35:44 AM
Maskng Region lines visible?
Thu, Aug 28, 2008 at 7:02:38 PM
cutting and slicing extruded solids ??
Wed, Apr 27, 2005 at 5:46:34 AM
Page generation time: 0.9009
