80 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to make a "Model in-place" a "Family"
Tue, Mar 15, 2011 at 3:57:14 AM | How to make a "Model in-place" a "Family"
shenlunglinnk
3 Stars: 2 Votes
Hi
I drew a "Model in-place" object in my project, then copied it 5 times for differenet places in the same project.
However I found that they became 5 families in my schedule (Object 1, Object 2, Object 3......)
In other words, if I change something in Object 1, all the other objects will not be changed.....
How can I make a "Model in-place" a "Family"?
Thank you
Tue, Mar 15, 2011 at 6:06:47 AM | How to make a "Model in-place" a "Family"
4 Stars: 202 Votes
I don't have revit here right now but try this: edit that "In-place" then copy several times, finish the edit mode and check.
"How can I make a "Model in-place" a "Family"?" - You can't, what you can do is create a "Group" with that in-place and save that group, then you can insert that group in other project.
Tue, Mar 15, 2011 at 7:21:07 AM | How to make a "Model in-place" a "Family"
shenlunglinnk
3 Stars: 2 Votes
Thank you very much :-)
Tue, Mar 15, 2011 at 3:01:24 PM | How to make a "Model in-place" a "Family"
TKennedy
4 Stars: 7 Votes
Something else you can try is starting a new family, editing the in place family in your procject, then doing a copy/paste into your new family. Save, then load into your project.
Tue, Mar 15, 2011 at 3:09:43 PM | How to make a "Model in-place" a "Family"
4 Stars: 202 Votes
I forgot that way Tkennedy, very good, I start to get old....
Thu, Mar 17, 2011 at 5:08:00 PM | How to make a "Model in-place" a "Family"
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"I forgot that way Tkennedy, very good, I start to get old...."Shiny Shiny Shiny ......
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:50 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:55 PM
Ceiling Plan tags in Linked Model Views "Moving" (2010)
Tue, Dec 21, 2010 at 7:20:59 AM
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:20 PM
model: column-"properties" dims not scaling to whats shown on drawing
Fri, Dec 12, 2008 at 3:10:12 PM
Page generation time: 2.8442
