57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> measure tape in section doesn work
Fri, Mar 11, 2011 at 7:00:14 PM | measure tape in section doesn work
Warchitect
4 Stars: 5 Votes
I get a "no go" symbol when I try to measure in section...is this normal?
Sat, Mar 12, 2011 at 4:57:32 PM | measure tape in section doesn work
You can measure in any view except 3D or perspective.
Sun, Mar 13, 2011 at 12:36:13 AM | measure tape in section doesn work
Warchitect
4 Stars: 5 Votes
I know that. but I use the section tool to draw a new section, and I get the circle with a slash through it. What does that mean? How could it be a 3d or camera view?
Mon, Mar 14, 2011 at 5:16:06 PM | measure tape in section doesn work
pchan
pchan Avatar
5 Stars: 5 Votes
Are you using the measing tape or the dimension tool?
the dimension tool (aligned) will only measure things when they are parallel but the measuring tape can measure things even they are not parallel
Tue, Mar 15, 2011 at 12:01:02 PM | measure tape in section doesn work
Warchitect
4 Stars: 5 Votes
So I took a screen shot. Take a look at the image and let me know if you see anything wrong with my settings..I want to measure the top of wall from floor to the roof. and the measure tool doesnt want to do it. I "illustrated in" what the cursor looks like (the screen shot doesnt capture the cursor).
 Im proficient at revit so its not a noob move like the wrong tool... but I cant figure this out.
Tue, Mar 15, 2011 at 1:01:33 PM | measure tape in section doesn work
pchan
pchan Avatar
5 Stars: 5 Votes
Then it seems like a bug to me
Tue, Mar 15, 2011 at 1:11:06 PM | measure tape in section doesn work
Works fine in my Revit 9 section view.  Cut a new section.
Tue, Mar 15, 2011 at 5:37:49 PM | measure tape in section doesn work
Warchitect
4 Stars: 5 Votes
THanks a lot! the deleting of the section and a redraw did it. I gotta remember that trick more.
tape measure tool doesnt work in elevation
Wed, Jan 12, 2011 at 1:19:05 PM
Tape Measure Properties [ 1 2 ]
Thu, Aug 21, 2014 at 12:15:13 PM
18
small dimension box & tape measure dimension
Sat, Sep 20, 2008 at 5:05:54 PM
Model Dimension
Fri, Feb 13, 2009 at 9:09:38 AM
How to change the number size on the tape tool and on the cursoe
Sat, May 1, 2010 at 4:46:45 AM
Page generation time: 0.8700
