42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> File naming when plotting to PDF
Thu, Mar 10, 2011 at 1:00:06 AM | File naming when plotting to PDF
wgarchitects
4 Stars: 2 Votes
Is there a way to specify how REVIT names files when plotting to PDF?
When I do a batch plot of a bunch of sheets or even a single sheet REVIT will automatically name the files using
"[File name] - Sheet - [Sheet number] - [Sheet title]".
I would like to remove the "Sheet -" and also the "[Sheet title]" from the file naming and add the "- [Revision number]" of each sheet at the end.
So it looks like this "[File name] - [Sheet number] - [Revision number]".
Is this possible?
Thu, Mar 10, 2011 at 7:14:05 AM | File naming when plotting to PDF
Thre is no way to do this in native Revit.
Thu, Mar 10, 2011 at 9:06:23 AM | File naming when plotting to PDF
TKennedy
4 Stars: 7 Votes
Google 'Bulk Rename Utility'. It's a free utility that will let you quickly do all sorts of renaming tasks.
Sun, May 1, 2011 at 6:11:52 PM | File naming when plotting to PDF
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can now do this with the new Revit API addon - Xrev Transmit.  Download the trial from the website.
Regards,
Chris.
Mon, May 2, 2011 at 11:40:29 AM | File naming when plotting to PDF
grid
^ Good info - wasn't aware of that API addon. Thanks!
Palm Springs Architect using Revit LT!
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Single sheet PDF Naming error
Tue, Nov 23, 2010 at 7:18:24 AM
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
RVT 9.1 - plotting as PDF changes lines to halftone
Tue, Jul 24, 2007 at 3:54:18 PM
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Page generation time: 3.8303
