25 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Automatic shared parameters
![albertiglesia Avatar](user_avatar/119685.jpg)
45 Posts No Rating |
hi, i'm just wondering if we could make the newly created shared parameters be automatically be shared once you use it to anothers project? please consider this case; i created title blocks with lots of additional "label" in it. since i'm not the only one who is doing the structure model and this will not be the only time we will gonna use this title block, it is only fitting to think that this labels should be automatically editable once it is loaded into other project otherwise we will always click the "shared parameters" & "project parameters" in manage menu tool bar everytime we use it into another project just to activate it into the project is it possible? if it is then how i'm eagerly waiting for your response thanks albert
"Pleasure in the job puts perfection in the work"
- Aristotle |
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
You need to create your own office project template or modify the default template you are using.
![pchan Avatar](user_avatar/55190.jpg)
![5 Stars: 5 Votes](/images/stars_5.gif) |
As far as I know, once you set the shared parameters and the associated label in the titleblock family (keep the shared parameter txt file in a centralized location so other people's workstation can access to the same txt file), you are good to go. You can use it for any other new project as long as the "label" applies to your nee.
Shared Parameters |
Thu, Feb 9, 2006 at 1:41:58 PM
Shared or Project Parameters? |
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families |
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters |
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid... |
Wed, Feb 12, 2014 at 9:31:26 AM
Members: | 2025983 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
