73 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> when exporting from sketchup to revit - urgent problem!
1 Posts No Rating |
Hello, I have a problem and I need to solve it fast! so may b someone can help me I did some plans in revit, then exported them to sketchup and worked on them there, after that, I exported them to a new revit file to continue working on the plans with the new sketchup things I've added, but the file I get in revit I get it as a block/group. I'vve tried to unblocked it and ungroup it but I can't . I cheked if in sketchup it was all a block or smething but I can't seem to work out where the problem is. It's impossible to get INTO THE BLOCK either on revit so I can't work on the file at all in revit! PLease! someone!!! HELP!!!!!! ![Smile](/images/smiles/smile.gif) THANKS JENNY
![coreed Avatar](user_avatar/14568.jpg)
sorry, that file will never be a true Revit file again.
![pchan Avatar](user_avatar/55190.jpg)
![5 Stars: 5 Votes](/images/stars_5.gif) |
For future reference, you should never use this approach, you will end up doing things twice...
Sketchup model into Revit |
Tue, Jan 8, 2013 at 12:06:20 PM
RENDERING PROBLEM NEED HELP URGENT... |
Fri, Dec 4, 2009 at 8:00:12 AM
revit into sketchup |
Sat, Dec 3, 2011 at 5:17:06 AM
Revit to Sketchup |
Fri, Apr 18, 2008 at 5:51:30 AM
Sketchup to Revit material problem [ 1 2 ] |
Wed, Jun 30, 2010 at 11:58:37 AM
26
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
