56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevation Text
![iamian33 Avatar](user_avatar/135203.jpg)
148 Posts No Rating |
Greetings. Will someone advise me on how to change the text for the Spot Elevation? Somehow our spot elevations now have text that is the wrong font/size, centre justified and located 'just to the left' of the target mark. In addition, the text angle is not horizontal/vertical. This happens only within a partial plan view where we used a scope box to 'square up' a portion of the plan that is at an odd angle. (The angle of the text is similar to the angle of the scope box >> 29d vs -29d). Don't know how it happened but I'd really like to bring this back under control. thanks.
Ian Shafer
Principal Consultant
True North S&F Consultants |
OK ... never mind. I believe that I found what I was looking for in the Type Properties. The 'Text Offset from Symbol' locates the text. This seems like a strange way to manage this ... there is no setting for Justify and the Offset needs to be a negative value in order to have the text above the line. Not sure why Revit does it this way, perhaps this is an example of the relic-like nature of the Spot Elevation. But if anyone out there has a better way to control the text in the spot elevation, I'd like to hear. Ian.
Ian Shafer
Spot Elevation Forced Text |
Fri, Apr 22, 2011 at 1:04:00 PM
border on a spot elevation tag |
Fri, Jan 29, 2016 at 2:52:39 PM
Spot Elevation Override |
Tue, Mar 5, 2024 at 7:26:45 PM
Spot elevations text on angle |
Thu, Oct 18, 2012 at 9:08:09 AM
Spot Elevation vs. Level elevation |
Wed, Feb 14, 2018 at 6:13:20 PM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
