30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Opening Heights
Thu, Mar 3, 2011 at 4:24:40 PM | Wall Opening Heights
suedehart
suedehart Avatar
I'm trying to insert  wall opening from floor height to 8'-0", but the opening keeps attaching itself to the roof level and even if I go into properties and select "unconnected" it still won't budge.  Is there another way to edit the height that I am not aware of?
Any advice is much appreciated.  Thanks!
Fri, Mar 4, 2011 at 7:34:33 AM | Wall Opening Heights
DeifyMe
4 Stars: 2 Votes
it shouldn't matter what the connected height is, can't you just drag the opening to the size you want using the grip points?
Fri, Mar 4, 2011 at 12:44:41 PM | Wall Opening Heights
4 Stars: 203 Votes
Why don't you just "edit" that wall and create the opening like you want?
Wed, Mar 16, 2011 at 10:43:21 AM | Wall Opening Heights
suedehart
suedehart Avatar
It won't let me drag from the top, that's what is weird.  It's like it has a top constraint that I didn't give it.
It's true I can edit the profile, but it makes it a little harder to edit later if we need to tweak things.
Thanks for the responses...
Wed, Mar 16, 2011 at 2:13:27 PM | Wall Opening Heights
pchan
pchan Avatar
5 Stars: 5 Votes
Have you tried to create a Generic void opening family that does the same job that you asked?
It might be helpful since it is not a system family or any sort.
If you make it parametic, then you can pull/push the shape handle  to make any adjustment
Wall heights - change all heights simultaneously
Wed, Sep 7, 2011 at 7:43:24 AM
Why do all my Wall Heights default to 20'-0" !!
Wed, Apr 26, 2006 at 4:31:21 PM
Control the depth of a wall opening?
Wed, Jan 19, 2011 at 2:09:23 PM
Wall Openings
Mon, Mar 9, 2009 at 2:40:22 PM
Why does the wall opening cut only go up 2/3 the height of the wall?
Sun, Feb 18, 2007 at 8:53:25 AM
Page generation time: 0.9725
