96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Embedded Detail Shows in plan view, but not in the plan detail call out!
2 Posts No Rating |
Revit Arch 2011: When any plan detail level is set to fine, the embedded detail turns on and the geometry turns off. Perfect. Make a detail call out around the objects to show at a finer scale, change detail level to fine and the geometry turns off, but there is no embedded detail. WHAT IS GOING ON? Plan view and plan call out, side by side. The embedded detail will not show up even with identical view settings and over rides. What is different about the callout and the parent plan it is originating from causing theembedded detail to dissapear? Please entertain any and all questions/comments.
I'm not sure what's going on. One thing for sure, call out from Drafting View will not capture Detail Lines drawn in parent. In model try also, Properties, Graphics, Show in, switch to 'Intersecting views'. See if that works.
Motto: "No Post left behind" |
copy & paste detail group from one plan view to another plan view (2017) |
Tue, Nov 29, 2016 at 4:57:42 PM
CALLOUT DETAIL VIEW VS. PLAN VIEW |
Wed, Mar 10, 2010 at 2:04:47 PM
Embedded detail component scale issue |
Mon, Oct 15, 2007 at 10:07:15 PM
plan detail callout in section |
Fri, Mar 29, 2013 at 12:48:11 PM
14
structure model disappear in the detail plan |
Tue, Jan 8, 2013 at 1:34:58 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
