92 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> Modify Floors in Section
2 Posts No Rating |
Hi- I have created a floor below grade to acquire a pit for a scissor lift. However, in section my floor is protruding into the existing footing of the foundation wall. If the footing and foundation wall are not in my model but in a shared linked model how do a cut away the tiny piece of my new pit floor so that it doesn't overlap the footing? I know that if the footing was indeed drawn in my model Revit would do this automatically but I am working with others and this is part of another linked model. Thanks in advance!
You will probably have to use a masking region or create the correct geometry in your view and turn off the linked element.
Floors not being cut in sections in 2013 |
Fri, Jan 11, 2013 at 8:44:07 AM
can't modify jogging section |
Mon, Jul 3, 2017 at 10:01:25 AM
Section line --goes up but not down |
Mon, Jun 21, 2010 at 6:03:12 PM
section mark across many levels |
Mon, Aug 13, 2007 at 10:07:26 AM
Section Mark Not appearing (i've checked the Hide scale...) |
Wed, Jan 31, 2007 at 3:32:33 AM
Members: | 2022512 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
