91 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Use Area Plan as my Floor Plan?
Mon, Feb 28, 2011 at 4:30:08 PM | Use Area Plan as my Floor Plan?
MYoung
MYoung Avatar
Revit 2011
Hi, I'm wondering if there are any downsides to using an "area plan" for construction drawings instead of a floor plan, since in floor plans you cannot use the area tool without fiddling around with rooms and/or parameters to get unit areas to show up.  So far I haven't found a good reason not to just use area plans throughout.  Can anyone shed light on the subject?
 Thanks
Thu, Nov 17, 2011 at 10:20:38 AM | Use Area Plan as my Floor Plan?
benwan108
I am considering this as well - it's great for multi-family projects, as Area Plans seem to be capable of hosting both Area Tags and Room Tags.
Has anyone since come up with a reason this wouldn't work? MYoung how did it work out for you?
Thu, Nov 17, 2011 at 3:54:17 PM | Use Area Plan as my Floor Plan?
MYoung
MYoung Avatar
Yes it works totally fine.  In fact I found no issues at all.  You will just find that there is a little bit of management required on the project browser as you will likely have some floor plans and a lot of area plans, but that doesn't matter; its just organization.
I just took the project in question through development and building permit, and no issues arose.
-Mike
Mon, Jan 25, 2016 at 6:53:55 PM | Use Area Plan as my Floor Plan?
JuliaS
Well I am currently trying to use my area plans in my documents for a minor project. My boss wants me to reference the area plans in my site plan, but when I try to use the "Reference View" tab, it doesn't have an option for area plans, and I can't figure out any way around it to reference them.
Did you have this problem?
Any help is appreciated.
Fri, Aug 30, 2019 at 12:31:03 PM | Use Area Plan as my Floor Plan?
demylin
I ran into the same problem as Julia S. I end up creating a new set of floor plans because I want to use reference view tags.
I am using these plans for now to show building area and there are some matchlines with reference view. However, I am worried that down the road, when I need to show Room area, I will need to redo the room area boundary and make the wall 'Room Bounding' again. (since Floor Plan doesn't allow you to used Aread Boundary and I am using 'Room Boundary' to measure the entire building footprint)
Anyway, these sound like a mess and probably not the right way to do it. Thanks ahead if anyone has a better workaround!
Area from Area plan to show on floor plan
Fri, Feb 27, 2009 at 7:53:30 PM
area plan from duplicated floor plan
Wed, Jun 3, 2009 at 8:38:27 AM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:04 AM
Area Plans.....
Thu, Jun 22, 2006 at 5:31:09 PM
Area plan
Fri, Jan 27, 2006 at 2:44:52 AM
Page generation time: 1.6617
