64 Users Online (63 Members):
Forums >> General Discussion >> Revit Project Management >> Object orientation parameter?
21 Posts No Rating |
Is there a parameter that distinguishes what rotation an object has once placed in a model? I want to control the on/off visiblitly of two labels in my annotation. If the object is within a certain angle range, I want one label on vs. the other. Thanks
Plan rotation is not normally set in the family but it can be. You would just have to build that in. I think this will be problamatic though because the tab key is normally used to rotate a family and users are accustomed to this. So your rotation read might not happen. I think it will also have to be a type parameter to work at all.
Thanks for the reply... I'm looking to extract the information from the model and use it in the family, if that makes sense. I don't want to actually be rotating the object itself. I just want to read the object's angle on the plan, and if it's within say 0-180 degrees, I want label 'a' (in my annotation) to be visible and not 'b'. If it's within 181-360 degrees, I want label 'b' to show and not 'a'. Thanks again!
61 Posts No Rating |
First things first, you want to stop thinking about "angle in plan" - as your plan view(s) can be set to any rotation respective of either true or project north.What you want to think about is an object's orienation to (I imagine) true north.We wanted to do this a while back to automate the population of shared parameter(s) we use for window, door & curtain panel glazing types - but it's not an-out-of-the-box feature - and I had no time to learn the method I found that used the API.I still don't.So instead we use view filters with colour overrides in a "working view" to check the fields have been correctly (manually) populated. Somewhat awkward, but easier our teams to handle and use...And the link? I'll go look for it now...
create a family parameter to orient object to show either landscape or portrait |
Wed, Aug 15, 2018 at 12:26:52 AM
3D View orientation won't lock |
Sun, Feb 26, 2012 at 7:44:07 PM
Locking Symbol Orientation |
Fri, Sep 11, 2009 at 5:20:27 AM
NOT Parameter Formula Question |
Fri, Apr 10, 2009 at 8:30:17 AM
Material Orientation Problem |
Mon, Apr 6, 2009 at 12:03:48 PM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
