78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dropped lines on plots
Tue, Mar 30, 2004 at 12:33:08 PM | Dropped lines on plots
skisouth
5 Stars: 3 Votes
Anyone had problems with tags on the curtain wall type causing the lines to drop on the plots? Preview pages show all lines correctly. Any tagged curtain walls seem to drop either a mullion or sometimes a system panel from the plot. Previews of plot show properly, all plotter types, However, both an Adobe PDF plot and any hardcopy plot - OCE or HP drop the lines. Tried on XP, 2000, and server 2003, all have the same issues (multiple machines).....
Tue, Mar 30, 2004 at 12:58:24 PM | RE: Dropped lines on plots
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
could be a memory problem. Try processing in the computer instead of the printer.
Hiroshi Jacobs
Tue, Mar 30, 2004 at 2:45:58 PM | RE: Dropped lines on plots
skisouth
5 Stars: 3 Votes
No, obviously I didn't make myself clear. The Adobe PDF printer is an all memory driver created by Adobe - comes with Acrobat Professional - Straight windows driver, there is NO printer as all processing occurs on the computer. The HP is a hard copy printer, tried this both across network and direct connect to printer, and finally the OCE driver is the driver we use to print to the service bureau, again processed on the computer entirely then plot file shipped to printer. In all three cases, three different printer drivers, three different manufacturer's, two different computers and operating systems, we get a consistent error, ONLY on TAGGED curtain wall types. One of the computers has four PIII's with a Gig of Ram and 10000 rpm Scsi arrays....This is Revit 5.1 - The other issue appears to be where the Leader of the wall type touches the wall is where the "blank out" of the system panel, entire section or what ever occurs. Once the tag has been placed, it makes no difference whether or not the leader is turned off or on for the wall type. There is omission of lines during printing only.... Anyway - I'm going to experiment some more.It appears to be the software, but who knows it could be the actual project file.... Thanks for the thoughts - If you have another idea, please post it.. Thanks... Post edited on 2004-03-30 16:05:54
Plotting
Fri, Oct 17, 2008 at 9:01:12 AM
plotting pdf's??
Sat, Jul 15, 2006 at 7:36:12 AM
Sheet title block plots incorrectly
Wed, Nov 3, 2010 at 10:44:30 AM
How do you darken hatch lines?
Thu, Jul 23, 2009 at 9:41:53 AM
Smart titleblock
Thu, Oct 20, 2011 at 3:38:53 PM
Page generation time: 6.3094
