54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> First Curtain wall assistance, please?
Sat, Feb 26, 2011 at 11:03:19 PM | First Curtain wall assistance, please?
Pele
Pele Avatar
I have just created my first curtain wall for a project in Revit 2011 & although it will probably do the task I want of it I would like to know how to adjust a few things.
All I am doing is recreating the existing one to carry on & document the office space in behind so I am not actually designing it for construction. I have attached an image of the existing.
  • The c/wall with the doors is actually two c/walls which is not what I want, I want one c/wall with a pair of doors in the middle.
  • Additionally the mullion above the doors needs to be about 300mm or about 12" size does not matter but I would like to know how to adjust it. This mullion is at 1st floor height so it will hide the floor structure.
I would dearly appreciate any assistance.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Mon, Feb 28, 2011 at 5:14:41 PM | First Curtain wall assistance, please?
pchan
pchan Avatar
5 Stars: 5 Votes
Hello Pele,
First off, you need have a double curtain wall door in order for that to work. don't put two single one together
there should be one already come with the box.
when you composed the curtain system as one wall, you should be able to select the curtain grid (by individual or by the entire length) then once you see the push-pin, unpin it and you should be able to move around the curtain grid, when u do, the mullion will follow.
Philip
Wed, Mar 2, 2011 at 9:23:06 PM | First Curtain wall assistance, please?
Pele
Pele Avatar
Phew !!
I did it, thank you very much pchan, see attached
Cheers Dermot
www.dmbd.net
Curtain Wall Panel to Curtain Wall Door
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Curtain wall panels with an arrayed profile
Thu, Mar 13, 2014 at 3:02:35 PM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Page generation time: 2.1104
