49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> crop region
Fri, Feb 25, 2011 at 11:51:08 AM | crop region
diesellam
I was trying to test the crop region of the floor plan.  See attached file.
I only want the left and right regions to be visible.  Why is the middle portion still visilbe?  (Even I have the "annotation crop" checked in the properties box.)
Fri, Feb 25, 2011 at 1:05:22 PM | crop region
cdfrantzis
as you can see, your actual elements are cropped by the crop region, it's just grid lines and annotation categories that are visible in the middle (detail lines, text, etc) these categories are not affected by crop regions as far as i know.
 what kind of lines are the red and blue ones in the middle there?
Fri, Feb 25, 2011 at 1:21:50 PM | crop region
diesellam
Red and Blue are just notation and dimension lines.
Is there a way I can make this work like the Viewports in AutoCAD, nothing in the middle shows up?
I thought the annotation crop in the properties box applies to this, no?
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:08 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:30 PM
crop region - elevations
Fri, Oct 23, 2009 at 12:43:34 PM
Room Tags Outside Crop Region
Sun, Sep 10, 2006 at 8:05:27 PM
datum controls and crop region
Fri, Oct 13, 2006 at 4:43:26 PM
Page generation time: 0.8864
