61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Two models in one session?
Fri, Feb 25, 2011 at 10:47:50 AM | Two models in one session?
maribeth
It's me again.  I have another question on my hospital project and splitting the casework from the base building.
I now have two distinct models with their own central files.  I've linked the base building model into the casework model and vice versa.  If I try to open both models in the same Revit session I get the following error message: "Cannot open the local model and the central model in the same Revit session.  You can either close one to open the other in the same Revit session, or open them in different Revit sessions."
So, it doesn't get much clearer than that, right?  I must open two Revit sessions if I want to view two models.  But, being a mistress of invention. . .does anyone know a "work around" for this problem, or if I just have to go with the Revit flow?
Thanks for any tips, help or pointers!
mb
Fri, Feb 25, 2011 at 1:15:49 PM | Two models in one session?
cdfrantzis
hi maribeth,
 unfortunately i think you just have to go with revit on this one. when you have a model linked into another, revit opens that file in the background. if you try to have it linked and opened at the same time, revit basically tries to open a file that it already has open and gets angry. if you want to have two revit models that are linked opened at the same time, you do have to use two revit sessions. or at least that should work... ive never actually tried it.
Fri, Feb 25, 2011 at 1:31:20 PM | Two models in one session?
maribeth
Thanks cdfrantzis!  Yeah, it works just fine if you have two Revit sessions open.  I was just wondering. . .
Thanks again!
mb
Multiple session annoyance
Tue, Jul 5, 2011 at 4:55:52 PM
Room Finish Schedule - Linked
Wed, Feb 17, 2021 at 3:52:41 PM
New Session Opens Automatically
Thu, Feb 10, 2011 at 10:58:14 AM
REVIT OPENS NEW SESSION FOR EACH FILE
Tue, Apr 19, 2016 at 8:11:03 PM
Copying Legends Between Projects
Wed, Jun 22, 2011 at 7:59:41 AM
Page generation time: 5.7612
