52 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Element in design option
hi there How to show on one design option a door in a wall and on the same wall but in second design option to show the wall without the door? And is there way to move back element from one design option to another? nirim
Hosted elements must have their host in that option. Thaty means you must have the wall in question in both options, one without the door and one with.
How do you mean? If I am in option two I can’t delete the door (it is in gray).
You can control what your view shows through VG. I suggest yout set up multiple views of each DO, then in VG, change the DO settings from automatic to the individual DO for that view. Then, in DO A, you have the blank wall and in DO B, you have the wall with the door. NOTE: To edit items in a design option, you must be working in that design option.
Edited on: Wed, Feb 23, 2011 at 11:12:38 AM
Railing wont host to stair created in design option |
Mon, Oct 24, 2011 at 3:54:39 PM
Cleaning Up Design Option Elements with Main Model Elements |
Wed, Jun 17, 2015 at 1:38:27 PM
Design Option Issue - walls in 1 design option cutting thru a 2nd option |
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting |
Fri, May 16, 2014 at 8:02:11 PM
Design Options - black hole. |
Wed, Feb 14, 2007 at 12:54:40 PM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
