44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wierd Crash
Tue, Nov 8, 2005 at 3:32:24 PM | Wierd Crash
lwasden
So I made a "fatal error" and O chose to save and exit and saved it under my file name. When I reopened Revit and opened the file it said the time it saved was when it crashed but the file it opened was an old version of that file that I had saved over several times since! Luckily for some reason the backup file with the".003.rvt" after the name was a more recent save(not the most recent). Is there any chance at all that that real file I saved is floating around on my computer somewhere? Or am I screwed?HELP ME PLEASE! Smile
Tue, Nov 8, 2005 at 3:43:05 PM | RE: Wierd Crash
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It is possible to recover the work using a journal file but something i wouldn't suggest a novice do. If you are confident in using revit. Journal files are kept in cPuhrogram FilesAutodesk Revit Building 8.1Journals... Each file keeps a record of everything you do in revit in each session. Locate the one with the appropriate time for when you experienced the issues. BACKUP ALL FILES OPENED IN THIS SESSION AND LOCATE THEM IN ANOTHER LOCATION This is because any saving you did during this session will be done again. To run a journal file, drag it onto your revit icon and sit back and watch. HTH.
Crash!!!!
Thu, May 5, 2011 at 4:09:10 PM
crash recovery
Thu, Apr 23, 2009 at 7:02:48 PM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 7:38:36 AM
11
Revit 2009-Wierd stuff happening.
Thu, Jun 25, 2009 at 2:46:00 PM
Revit Link causes crash
Wed, Dec 29, 2010 at 10:33:38 AM
Page generation time: 1.6997
