19 Users Online (18 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> scale of text
Mon, Feb 21, 2011 at 10:42:54 PM | scale of text
diesellam
Please see the attached file.
It looks right when it's in default scale (1/8"=1'-0"Winking
But when I switch to 1/16" scale, the right arrowhead looks angled and tweaked?  Is there a way to avoid it?  I have lots of this text all over the plan, thanks in advance.
Mon, Feb 21, 2011 at 10:49:48 PM | scale of text
diesellam
I can't shrink the file to less than 2mb even with just 1 text in the file.
Tue, Feb 22, 2011 at 7:22:40 AM | scale of text
Use something like screenhunter free to capture your screen and post that.
Tue, Feb 22, 2011 at 9:40:20 AM | scale of text
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You do not have to upload the revit file just an image.
Do screen capture with ALT+PRTSC or the Windows 7 Snip tool.
Then upload that image here.
Tue, Feb 22, 2011 at 11:08:14 AM | scale of text
diesellam
See attached PDF file of the snapshot.
The upper one is 1/8" scale; the lower one is 1/16" scale.  It's the same annotation.  The only thing's changed is the graphic scale under properties.
Tue, Feb 22, 2011 at 11:37:19 AM | scale of text
This happens because the tag is now directly above where the leader points.  If you don't want this to happen, the leader has to come off the end far enough that the scale change doesn't do this.
Tue, Feb 22, 2011 at 11:43:28 AM | scale of text
diesellam
This is going to be tough because most of the time this note applies to two curbs that are close to each other.
Tue, Feb 22, 2011 at 2:20:21 PM | scale of text
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
here is an option for you
if this text will basicly remain the same, you could create a generic annotation family.  You will need to draw the leader lines, (text in the generic family does not have leader option it is greyed out)
Once you have your generic text created to the correct size and all you can place this family as needed and it will scale as you expected it to.  Plus you can create different versions of this text and nest the families to give you more options.
I hope this helps
 ----edit----
I don't think this concept will solve your issue 100%.  The leaders don't go all wacko when you change scale but you still need to move your generic text family around to relocate it once you change the scale.
 It was an idea though....
Edited on: Tue, Feb 22, 2011 at 3:24:40 PM
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Tue, Feb 22, 2011 at 3:19:15 PM | scale of text
diesellam
Cadman,
Thanks for the suggestion as always.  I appreciate it.  Hope they can make this a much easier process in the future release.
Can someone explain text scale to me?
Fri, Nov 14, 2008 at 9:17:35 PM
Scale of Text in Views?
Thu, Jul 17, 2008 at 7:37:17 AM
Text in Families That DOES NOT Scale??
Fri, Jan 16, 2009 at 3:21:38 PM
View Title scale text won't show
Tue, Dec 29, 2009 at 2:36:51 PM
Text in Families
Fri, Jul 21, 2006 at 11:34:55 AM
Page generation time: 1.4526
