90 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> adding material to a dxf object
Tue, Nov 8, 2005 at 6:59:01 AM | adding material to a dxf object
amaruna
1 Stars: 3 Votes
I've imported some objects into my scene and I've changed the material by going into settings-object style-imported objects and it worked.But I do have a problem ..after importing a few objects the default material can't be changed or duplicated and the result is that all the imported objects have the same material attached.
Wed, Nov 9, 2005 at 11:13:35 PM | RE: adding material to a dxf object
eldados
eldados Avatar
4.5 Stars: 8 Votes
that's right, you can't apply material to a dxf or dwg, and changing the object style is changing globaly...
Integrator
KarelCAD
adding a material to and object and it does not layout right???
Mon, Jun 27, 2011 at 7:15:42 PM
import 3D model in DXF or DWG - how use it?
Mon, Oct 31, 2005 at 9:28:46 AM
how to know the material used in a specific object?
Mon, May 9, 2011 at 1:14:24 PM
File with Linked Model, to DXF, with no blocks in DXF
Mon, Nov 21, 2016 at 9:43:03 AM
Adding Material to Families based on Cad Imports
Tue, Jun 23, 2009 at 11:37:01 AM
Page generation time: 0.6953
