27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating Topo using an image
Mon, Feb 21, 2011 at 1:32:57 PM | Creating Topo using an image
Joetaba
I'm trying to create a topo surface using an image for the contour locations.
The problem is visibility; If the image is set to foreground the image hides everything and I cannot see what I'm doing. if the image is set to background the minute i pick 3 points the topo begins to cover the image and I cannot see the contours or what it is i'm trying to follow. I tried overriding the topo surface to transparant but if you click edit surface the topo reverts back to opaque during sketch mode and you cannot see the contours below.
Is there a way to bring the image in so I can see through it and set it to foreground? (I tried using photoshop to delete the white background, tried turning the opacity to 50%, but saving the file to a jpeg, tiff, bmp for revit to insert automatically creates a mask the size of the image) Or, any other suggestions would be helpful. Thanks.
Mon, Feb 21, 2011 at 2:18:32 PM | Creating Topo using an image
4 Stars: 203 Votes
Change your "View mode" to "Wireframe"
Image over Topo Surface
Thu, Oct 2, 2008 at 7:56:15 PM
topo depth
Wed, Nov 7, 2012 at 2:17:31 PM
14
"Modeling Topos" & Topo's from grade or point?!?! Topo Conceptual Mass?
Fri, Aug 4, 2017 at 5:52:31 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:01 AM
VOIDING TOPO FOR FNDN HOLE??
Wed, Jun 7, 2006 at 3:26:48 AM
Page generation time: 6.4123
