72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Rendering problem - Out of ideas!
2 Posts No Rating |
Ever since i got a new pc in september last year, i havnt been able to render on revit 2011, or should i say, finish a render what it does is random, it will not render on HIGH or BEST settings (printer or screen resolution). it will simply do a range from 10-99% and just stop. it will be at 40% for example, then just go to 100% and stop rendering. just a quick spec for u on my system win7 ultimate 64bit Ram - 4x2gb sticks (8gb total) CPU - i5-760 OC 4.1ghz (cooled) GPU - Radeon 5850 ok so thats out of the way. i have run memory tests on mem86+ and no problems. 27 passes 0 errors. people say you need more RAM to render on 64bit, maybe, but 8gb is surely enough. and to put it in perspective. i had to use my laptop with 2gb of ram to render a 5000x2000 300dpi BEST settings to get my work done. albeit it took 2 days and 18hours. but it did NOT crash. can anyone hazard a guess at why my revit on the pc is not rendering?
possibly the overclock. Revit won't deal well with any errors from an overclock.
2 Posts No Rating |
i had a feeling it could just be from overclocking, however, i cannot afford to drop the speed as revit is the only thing not working on the pc (when rendering anyway) nooo ._. and i thought overclocking would actually help it render..
I you're crashing during rendering you could also be corrupting files. That isn't going to help anything go faster.
atleast see if that solves the problem.
Hate to reopen an old thread but I am having a very similar issue with revit 2013 on an 17 O.C.'d to 4.8ghz. Rendering atarts for about 2 min then just skips ups to 100% It is maddening. Did removing the overclock help? Or does anyone have any ideas on how to solve this problem?!
I have stress tested all of the hardware (memtest86, intel burn test, etc) all passed.
HELP!
Thanks!
problem rendering in 2010 |
Sat, Apr 24, 2010 at 2:38:51 PM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ] |
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem |
Wed, Feb 6, 2013 at 1:41:48 PM
Rendering... Block Walls and Floor |
Wed, Apr 8, 2009 at 8:28:39 AM
Problem while rendering |
Tue, Feb 12, 2013 at 1:37:23 AM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
