68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> roof by extrusion not working
Sun, Feb 20, 2011 at 1:24:19 PM | roof by extrusion not working
sroreilly
At home I'm using R2010 (at work, 2011)
So, here I am attempting to try someone's idea of creating a curved wall that goes up to the bottom of a curved monolithic stair by creating an extruded roof etc etc... (seen in a forum).
I cannot create an extruded roof! I've followed the directions in a book, and the Help files with no luck. I am greeted with the message "can't make extrusion" each time I try. Obviously, I'm missing a step or some such thing.
 Here are the steps that I've followed:
1 drew 4 walls
2 created a reference plane parallel to the 'front' wall & gave it a name
3 selected 'roof by extrusion', selected the 'front wall' reference plane & selected the 'front' view
4 sketched an arc shape (also tried a pointy roof!) and finished the sketch
5 was greeted by 'can't make extrusion' message (over & over).
 If anyone is out there today, would you be so kind as to offer a pointer???
Sign me:
"Exasperated in the snowy, frozen north with a dead battery so I may as well learn more Revit"....
Sun, Feb 20, 2011 at 9:25:27 PM | roof by extrusion not working
mcantwell
mcantwell Avatar
Followed your instructions
Worked like a charm.
was in clean template, but no idea why yours fails
Revit 2011
Sun, Feb 20, 2011 at 10:19:19 PM | roof by extrusion not working
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sounds like your work plane or extrusion settings are off.
You may want to try watching these CADclip Videos on creating a curved wall under a curved stair.
Edited on: Sun, Feb 20, 2011 at 10:20:38 PM
Mon, Feb 21, 2011 at 8:22:22 AM | roof by extrusion not working
sroreilly
dgcad:
Yep, I followed your cadclip too. (As best I could, as I can't get audio with that one.) They are good, by the way.
"Extrusion Settings"?
I am frequently be-fuddled by settings which seem obvious to others!
Mon, Feb 21, 2011 at 8:56:04 AM | roof by extrusion not working
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I am not exactly sure what you are trying to do and what the problem is howerver, start with:
1. making sure you are on the right / desired workplane.
2. Don't skecth a closed loop when creating the roof. Keep it open ended.
3. Note the roof reference level and offset.
3. Note the extrusion start and end settings in the the properties palette.
4. Note and probe into the roof type.
See if you can at least create a roof by extrusion in a new project.
You must be doing something fundamentally wrong and not explaining it and we're not picking it up.
Mon, Feb 21, 2011 at 12:22:43 PM | roof by extrusion not working
sroreilly
Thanks for replying....
I did finally get an extrusion to work. So, I've gone back to the curved stair & wall to try again.....
I managed to make an extrusion & get the wall to attach, but I'm sure that I did it wrong. In answer to your list:
1. ref plane: front, elevation: front (attachment #1)
2. didn't use a closed loop
3. I think this may be where I'm losing it. See attached please? (#1 & #2 is what I'm attempting now, #3 is what I got to work) #3 I created from the second floor, #2 I'm creating from the 1st floor (just to confuse myself even more!)
4. roof type: created 'thin' with 1" thickness
Well, I'm sure I've not explained myself very well before, is this better? Maybe I need more coffee?  Yep, tryin' to keep my sense of hah-hah.
Tue, Feb 22, 2011 at 4:13:04 PM | roof by extrusion not working
sroreilly
It seems that I cannot make a thin extruded roof by picking an existing line or edge.
I have made a thin extruded roof by drawing lines. But then the wall will not join the roof.
Still be-fuddled. Confused. Frustrated.
This seems so wonderfully straight-forward and simple, yet I cannot get it to work!
Sat, Feb 26, 2011 at 1:41:40 PM | roof by extrusion IS NOW working!
sroreilly
This past week I got this problem licked. :o
Seems I just don't yet get the Revit lingo.
I placed a reference line parallel to the curved wall & staircase that I wanted to edit. (Well, as parallel as you can get to a curved wall....) Yes, even though I read parallel & wrote parallel, it never sunk in. (Must've been the bad cold.)
I also placed a section view parallel to these items. I then created the thin roof, stretched it around as required, made sure that it was a little bit above the wall at the lowest portion, and attached the wall to the roof.
Voila. Success.
Thanks for the attempts to help.
Now. On to creating other stuff....
Learning more & more on a blustery, snowy day....
Barrel tile roof by extrusion
Fri, Jan 14, 2011 at 1:10:18 PM
Revit 2012 Roof by extrusion
Sat, Nov 19, 2011 at 4:49:21 AM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:15 AM
"Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
Mon, Jun 5, 2017 at 10:57:15 AM
Roof Extrusion Trouble
Tue, Mar 5, 2013 at 12:43:02 PM
Page generation time: 0.6554
