127 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> 3D Views are transparent
Wed, Feb 16, 2011 at 4:25:19 PM | 3D Views are transparent
pmobleyjr
3 Stars: 1 Votes
I have been working in Revit MEP 2011 and doing electrical Drawings. The engineer asked for a 3D print out and I can see the walls of the linked model but all of our devices show through the walls.
I went to View Graphics and made sure that the halftone and transparent are unchecked but it is still showing through. I have went online and to Revit help but can't see anything about this kind of problem. Is there something I am missing in the View Graphics Dialog Box. Or is there another setting where I can get the walls of the linked model to be opaque and not show devices from the far side?
Wed, Feb 16, 2011 at 5:13:31 PM | 3D Views are transparent
TKennedy
4 Stars: 7 Votes
I've been seeing the same thing in one of my models, and it appears to be caused by the phase settings. Unfortunately, I have not been able to figure out how to make it stop (I haven't had the time to look at it much, and it's not a huge problem yet), but that should give you something to look at.
Wed, Feb 16, 2011 at 11:05:43 PM | 3D Views are transparent
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
If it's caused by the phase settings, check your phase graphic overrides.
cad.web.print
Mon, Feb 21, 2011 at 10:11:49 AM | 3D Views are transparent
pmobleyjr
3 Stars: 1 Votes
OK guys I found the problem. In elevations and #D go have to go to the disipline settting in properties and change it to coordination and that sets wall as opaque. It works well and takes out the show through problem
Fri, Aug 3, 2012 at 2:57:24 PM | 3D Views are transparent
GrizTiger
Thanks for this post.  I have been banging my head on the keyboard for over an hour!!
Transparent object
Tue, Sep 14, 2010 at 1:18:35 PM
Transparent materials rendered as solid in 3d views?
Thu, Jan 5, 2017 at 8:03:56 AM
revit arch 2013 my 3d views are transparent???..
Mon, Mar 25, 2013 at 7:45:26 PM
elevations have gone transparent
Wed, Jun 6, 2012 at 6:02:05 PM
3d views are transparent in revit 2013
Tue, Apr 24, 2012 at 8:06:01 AM
Page generation time: 1.9210
