36 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> Need Help With Links
![4.5 Stars: 6 Votes](/images/stars_4.5.gif) |
I have created two files: 1 file is the site and the other file i have modeled my buildings in. I have inserted my Building model into the site file. Now my problem is with my railing materials, for some reason I can not change them to black. In the bldg. model file I have applied the correct material and the railings are black in the file. Not sure whats going on any ideas would be great. Thank you!
Typically, I want to render from the file that has the correct settings. So I would link the Site into the building and render from that.
Ummmm that sounds like a work around but I will try it b/c i need to get this done. I would really like to know what the problem is though.
![cadman6735 Avatar](user_avatar/82004.jpg)
![5 Stars: 4 Votes](/images/stars_5.gif) |
Make sure the material in your site file matches the material in your building file. (same name and same materials) Revit, for some reason will, even though you have set the material correctly in the file you modeled your element in, if the materails in the host model have the same name but different material assigned to it, the linked model will take on the material properties of the host model. But this is just a blind guess and only from my experiance from what you describe Hope this helps
Quote by: Holtz, Lou
My explanation above if for families not links, so check your family materials, make sure your project materials match your family materials. If it still does not work, upload the file.
Trouble converting links to groups |
Tue, Oct 25, 2016 at 12:12:21 AM
*URGENT * - Worksets & Links |
Mon, Oct 12, 2009 at 5:51:32 PM
Links |
Wed, Jul 28, 2010 at 7:07:06 PM
MANAGE LINKS |
Tue, Nov 10, 2009 at 7:41:25 AM
Save to Central or Revit Links |
Tue, Sep 4, 2007 at 2:56:57 PM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
