124 Users Online (123 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Dimension Override
Wed, Feb 16, 2011 at 2:26:17 PM | Dimension Override
patton
5 Stars: 2 Votes
I'm using Revit Structure 2011. Is there anyway that I can add more than a total of 3 lines of text into a dimension override. Currently I add text to the above field, then replace with text, then the below field. I would like to be able to create more than just those 3 lines of text in some cases. The only thing I've seen before was in a label that somebody had created by copying text from Word that had a hard carraige return in it and pasting it in which seemed to work for the label. I don't want to have to open Word every time that I want to do this. Does anybody have any idea if this is possible?
Thanks
Dimension Override with numbers?
Mon, Feb 7, 2011 at 3:29:51 PM
Dimension Override
Wed, Apr 12, 2006 at 3:17:16 PM
Dimension Text Override [ 1 2 3 ]
Wed, Apr 24, 2013 at 4:16:16 PM
34
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:08 AM
18
how to override values of level grids?
Thu, Jul 5, 2012 at 3:54:00 PM
Page generation time: 1.6126
