54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Remove border from hatch/ fills
Wed, Feb 16, 2011 at 6:58:22 AM | Remove border from hatch/ fills
assaultmoose
How do I do this? I can't find a solution anywhere!
Many hatches - eg: earth - look terrible with the border/outline on! What can I do?
Wed, Feb 16, 2011 at 7:08:32 AM | Remove border from hatch/ fills
Just choose the right line for your sketch when you create thge filled region - called invisible line.
Wed, Feb 16, 2011 at 7:14:57 AM | Remove border from hatch/ fills
jonezy
edit the sketch, then select the pink/purple boundary lines and change them to invisible lines in the drop down menu in the top left corner of your screen
Wed, Feb 16, 2011 at 8:15:30 AM | Remove border from hatch/ fills
emgeeo
3.5 Stars: 7 Votes
The lines which define your hatch region need to be <Invisible>
1.  Select your hatch
2.  Edit sketch
3.  Select lines which need to be hidden  (if all, you can use the tab key)
4.  Change line types to <Invisible>
5.  Finish sketch
6.  See video if not clear.  http://www.screencast.com/users/MOwens/folders/Jing/media/d2a69ad5-d61f-4dc5-b98d-f6fd9fd7ed17
Thu, Feb 17, 2011 at 4:38:52 PM | Remove border from hatch/ fills
assaultmoose
It's so obvious - I'm embarrassed I didn't work it out earlier!
Thanks everybody!
Hatch Question
Fri, Jan 9, 2015 at 10:31:31 AM
Export fills to layers
Fri, Sep 11, 2009 at 11:51:48 PM
EXPORTING TO AUTOCAD- WITH NO COLOR FILLS
Sat, Mar 31, 2018 at 3:07:57 AM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:05 AM
Wishlist - Floor fills
Fri, Jan 14, 2011 at 5:26:55 PM
Page generation time: 0.5075
