110 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> Curtain System by Face
4 Posts No Rating |
Every time I insert the stock double glass door into a Curtain System by Face, it turns it 90 degrees (in elevation) within the opening. However, when I insert the very same door into a Curtain System created by lines, it works correctly. What is going on???
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
hmmm... tried to duplicate your problem but can't, it works fine for me...
never had a problem with this in the past.
have you tried inserting another door?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
I've experienced this before on a canted wall...
Solution was to either create it by lines or create a door panel that is rotated 90 degrees. Sent it to the support team and i believe it was one of those issues that didn't make into 8.1 and should hopefully be fixed in the next release.
4 Posts No Rating |
This one showed up in the Autodesk discussion group this morning. I think you are right...8.1 has a bug...
It's a real shame, too, because this is probaly one of the most powerful tools in REVIT. I was so excited after using A-Desktop's clunky curtain wall system for years.
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
Regular grid on Curtain system by face |
Mon, Sep 30, 2013 at 2:57:17 PM
Splitting a sloped wall by face into wall / curtain system |
Fri, Jun 13, 2014 at 3:41:54 AM
Curtain System Problem |
Sat, Sep 16, 2006 at 5:09:13 PM
Flip Curtain Wall By Face? |
Thu, Jun 21, 2007 at 6:12:13 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
